ChangXray's avatar
ChangXray
Orbi setup: AC2200/RBK30 connecting to netgear modem CM500
Internet provider: Spectrum Xfinity cable
Cable modem: Netgear CM5OO
WiFi router: Netgear N600WND R3400
I just bought an ORBI AC2000/RBK30 and followed the orbi setup instructions.  My iphone could not recognize the orbi device to complete the set up.  This is what I did so far... Should I set up using my laptop hardwire to ORBI rather than thru my iphone ?
- disconnect my netgear wifi router from modem
- hook up orbi to my modem
- download orbi app from apple store
- turned on my wifi on the iphone
- got a message saying ORBI device not found.
Should I set up using my laptop hardwire to ORBI rather than thru my iphone ?  Please help!  Any advice is appreciated!
  • FURRYe38's avatar
    Use a wired PC and web broswer pointed to 192.168.1.1 and setup the using the RBRs web page.
    Review the installation guide PDF as well.
  • Yes, using a computer connectee to the router's ethernet port and using the Orbi's web interface is the best way of setting things up.
    How do I set up my Orbi router and satellite?
    My preference in in red in Steps 10, 11 in the above link:
    • Connect your computer or mobile device to the Orbi router or satellite with an Ethernet or WiFi connection.
      Note: To connect with WiFi, find the preset WiFi network name (SSID) and password on the label on the Orbi router or satellite and connect to that network from your WiFi-enabled computer or mobile device.
    • Download the Orbi app or visit http://orbilogin.com to set up your Orbi WiFi network.
      The Orbi router's ring LED turns off after the setup is complete.
    • ChangXray's avatar
      ChangXray
      To: Vajim,
      Here is my response. . .
      it looks like you have 2 routers in your system?  Is that true?
      - No, I do not have 2 routers, I am disconnecting the N600WND R3400 and connecting my ORBI to the modem.
      Thanks,
  • FURRYe38's avatar
    Remove the R3400 router and use the Orbi router as your main host router.
