TomiPhone
Dec 02, 2018Follower
Orbi setup as Router or AP?
Hi there, Just purchased the Orbi and was wondering what the best setup is? I have a Ziggo modem/router. Should I setup the Orbi as router (Ziggo in bridge mode) or as AP? Thanks in advance for your...
- Dec 02, 2018
There is no right or wrong answer. If you like your Ziggo's router features, then use Orbi in AP mode. If your Ziggo modem/router has bridge mode, then you have the option to use Orbi in router mode. I use my Orbi in AP mode because I have another router with better routing features and no WiFi.
st_shaw
Dec 02, 2018Master
