skyjuice
Jan 08, 2017Aspirant
Orbi Setup-Using my old wifi network name
I'm going to set up my new Orbi system soon. How do I use my current/old wifi network name so all of my devices(Nest/Sonos/laptops/phones) continue to connect? Or do I have to start over an...
skyjuice
Thanks Chris!
So I assume I will need to keep my Airport Extreme plugged into power so it continues to broadcast ms SSID?
Also, I have two bands, 2.4 and 5ghz. Orbi will naturally select the highest band correct?
Appreciate your response.
-Sky
Hydro130
Jan 08, 2017Luminary
If you are bridging your Orbi to your existing router, I don't have any experience with how that works, sorry.
I myself totally replaced my old Asus router with the Orbi (no bridging or AP setup) - I just used the same SSID and password when I set up the Orbi.
