JABuntyn's avatar
Aug 23, 2017
Orbi Setup
How do you set the date and time on the Orbi WiFi Router?  Seems that there should be a setting to get the date and time from the internet.  I've seen the time zone setting on the 'Schedule' tab.   ...
  • st_shaw's avatar
    st_shaw
    Aug 24, 2017
    Review the Orbi logs.  If NTP is wokring you should see something like:
    [Time synchronized with NTP server] Thursday, August 24, 2017 16:25:40
    Make sure the Orbi device has valid settings for the gateway and domain name servers.
    If you are behind the FIOS router you should run Orbi in AP mode, or bridge the FIOS router. This shouldn't affect NTP though, unless Orbi's network settings are misconfigured.
