SLK-Purdue
Apr 21, 2020Luminary
Orbi, SOAP, and Excel
In previous post I have tried to improved the Connected Devices display in the WebUI (added sorting) and put together an Excel spreadsheet to extract that data. I still wanted signal information. T...
- Apr 26, 2020
I updated to 2.5.1.16 FW and things seem to be working fine.
I can also confirm my Excel stuff and the mods for sorting Attached Devices all port the same for 2.5.1.16 and work.
Scott
SLK-Purdue wrote:Thanks. Will give it a look.
FURRYe38 wrote:v16 is available now:
Apr 21, 2020Guru - Experienced User
Was curious if you have updated FW to v16?
I know that CrimpOn and you were discussing this here:
https://community.netgear.com/t5/Orbi/Attached-Devices-Sorted-by-IP-Number/m-p/1877986
Also Voxels FW should have some improvements as well.
SLK-Purdue
Running 2.5.1.8
FURRYe38 wrote:Was curious if you have updated FW to v16?
- FURRYe38Apr 21, 2020Guru - Experienced User
- SLK-PurdueApr 21, 2020Luminary
- SLK-PurdueApr 26, 2020Luminary
Scott
