SLK-Purdue
Apr 21, 2020Luminary
Orbi, SOAP, and Excel
In previous post I have tried to improved the Connected Devices display in the WebUI (added sorting) and put together an Excel spreadsheet to extract that data. I still wanted signal information. T...
- Apr 26, 2020
I updated to 2.5.1.16 FW and things seem to be working fine.
I can also confirm my Excel stuff and the mods for sorting Attached Devices all port the same for 2.5.1.16 and work.
Scott
SLK-Purdue wrote:Thanks. Will give it a look.
FURRYe38 wrote:v16 is available now:
CrimpOn
May 23, 2020Guru - Experienced User
This Excel sheet is amazing! It now removes any incentive to open the Orbi "app" as the only thing the app does that the web interface does not is show the "Link Rate" and signal strength.
Was surprised to see the satellite signal strength on my satellite is (minus) 64, whereas all the other devices show signal strength as positive numbers. The spread sheet does not show transmit/receive speeds that I see in
satelliteinfo wifi
That data is probably not in the information SOAP returns?
GREAT WORK
SLK-Purdue
May 23, 2020Luminary
Thanks. I will check if that data is available somewhere.
Scott
CrimpOn wrote:This Excel sheet is amazing! It now removes any incentive to open the Orbi "app" as the only thing the app does that the web interface does not is show the "Link Rate" and signal strength.
satelliteinfo wifi
GREAT WORK
