sonnylax
Jan 03, 2017Guide
Orbi Speeds Slow After Initial Install
Just got my Orbi (Router & Satellite) WiFi system up and running in AP mode behind my AT&T Uverse/GigaPower Gateway. I'm paying for a 1 Gigabit connection, but I believe AT&T only guarantees 800 Mbp...
Ely
Jan 03, 2017Luminary
Can you disable Wi-Fi on your AT&T Uverse/GigaPower Gateway and make it work just as a modem, then use your Orbi as your router instead? this will not solve your problem but it might be a work around.
sonnylax
Jan 03, 2017Guide
thanks... already disabled the WiFi functionalty on the AT&T Gateway....
- ElyJan 03, 2017Luminary
Do you still have the Orbi running as an AP though? have you tried it as your main router and if so is the speed still bad?
- sonnylaxJan 03, 2017Guide
Thanks for the tips.... Keep em coming. I was able to manually update the Firmware on the Orbi Satellite. I've also got the Gateway configured as DMZ+ (PassThrough).
When I'm hardwired into the Orbi Router, I'm seeing good speeds (541 Mbps down) which makes me think I've got something configured wrong on the Orbi.
I wonder if it has something to do with QoS, I have seen people saying if it is disabled or not properly set it can cause speed issues via Wi-Fi, perhaps you should try doing a factory reset and starting fresh? it could be a pain if you already have made a lot of changes, but otherwise might be worth a shot.
IPv6 should be enabled - right???
RIght now, its DISABLED.
Here are my choices:
Auto Detect
Auto Config6to4 Tunnel
6rd
Pass Through
Fixed
DHCP
PPPoE
- 62cwilJul 08, 2017Aspirant
How do you disable the wi fi functionality on the AT&T Router. The tech told me the program did it but since I only getting speed around 22 something not right.
- gaurmJul 12, 2017Aspirant
Go to your router's ip address on your browser (mine is 192.168.1.254), go to home network/wifi and disable both the 2.4 and 5ghz wifi bands
- 62cwilJul 12, 2017Aspirant
I only see the 2.4 ghz bank which I did disable. Don't see a 5ghz one. After disabling the 2.4 one I still only get around 30 mbps speed which is same. Any other suggestions as I understood I would get much faster speeds.
