sonnylax
Jan 02, 2017Guide
Orbi Speeds Slow After Initial Install
Just got my Orbi (Router & Satellite) WiFi system up and running in AP mode behind my AT&T Uverse/GigaPower Gateway. I'm paying for a 1 Gigabit connection, but I believe AT&T only guarantees 800 Mbp...
sdunlap01
Apr 23, 2017Guide
So these issues (at least for me) do indeed relate to the QOS/WMM settings.
I found a WMM setting in my laptop wireless adapter configuration, enabled it and saw some improvement after reenabling the QOS/WMM settings in the Orbi. Just the fact that I saw differences confirms my connectivity issues are revolved around these features.
Another beef I have is my 5Ghz capable devices are no longer connecting at 5Ghz but I see that is also a separate issue/forum.
Netgear, I've been a long time customer, please resolve these issues so we can remain so. I need my connectivity between my ISP connection and my devices to remain constant and I need my 5Ghz capable devices to be able to connect at 5Ghz (none of them have since switching from my Netgear R7000 to the Orbi).
sdunlap01
Apr 24, 2017Guide
Enabling the following two features has had a negative impact on my uptime.
| Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices |
| Enable MU-MIMO I disabled them again and will now monitor once more but I can tell how well my connectivity (both wired and wireless) is performing based on my security camera outages/disconnects. Enabling the above 2 features caused more disconnects than I've seen to date. So i'll be disabling them again to retest and will post results at later date |
- sdunlap01Apr 24, 2017Guide
Wow, that didn't take long. As soon as I disabled those two settings (see below) under the Advanced Wireless menu, my Orbi wall plug satellite immediately began communicating again and now shows devices connected where I struggled to get the wall plug satellite to even sync with those 2 settings enabled much less communicate with my devices.
Performance/uptime is still yet to be determined but I can 100% definitively tell the following settings caused my network degradation :Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices Enable MU-MIMO
