sonnylax
Jan 02, 2017Guide
Orbi Speeds Slow After Initial Install
Just got my Orbi (Router & Satellite) WiFi system up and running in AP mode behind my AT&T Uverse/GigaPower Gateway. I'm paying for a 1 Gigabit connection, but I believe AT&T only guarantees 800 Mbp...
talbert99
Oct 04, 2017Aspirant
Just hooked up RBR50 with three RBS50 as I have ethernet connected devices. The throughput is horrible - general WiFi access through my home is the worst i've ever seen. Is there a problem hooking up mulitple satellites? How do you test ORBI to Device speed - and where is the QoS option in latest firmware? (currently on 2.0.0.74). I have IPTV devices connected to the satellites and have to reset my system to get any kind of throughput. Looking for an idea?
aaz
Oct 06, 2017Virtuoso
talbert99 wrote:Just hooked up RBR50 with three RBS50 as I have ethernet connected devices. The throughput is horrible - general WiFi access through my home is the worst i've ever seen. Is there a problem hooking up mulitple satellites? How do you test ORBI to Device speed - and where is the QoS option in latest firmware? (currently on 2.0.0.74). I have IPTV devices connected to the satellites and have to reset my system to get any kind of throughput. Looking for an idea?
What kind of internet connection do you have?
What kind of speed do you measure using speedtest.net when wired to the router?
What kind of speed do you measure using speedtest.net when on Wifi to the Router? When connected through a satellite?
How many and what kind of devices do you have on your wireless? Are they 5Ghz? Are any of them 11b?
Are you running the Orbi as the Router? And is your ISP modem bridged? Or are you NATing through it?
If you are seeing full speed after reseting the Orbi, then chances are that one of your devices on the network is what is causing the problem - you are seeing full speed until the devices reconnects or starts to act up again.
I'm only running two satellites, but have not seen the issues you mention. I have quite a few camera's and streamig devices.
- rgadueOct 20, 2017AspirantI too have issues with constant reliable speeds. I have Orbi router w 2 satellites. Orbi router installed downstairs in family room, 1 satellite upstairs in loft, 2nd satellite, in garage. Xfinity 1g service. Arris surfboard 3.1 sb8200.
Devices connected, multiple iPhones and Macs, Android phones and PC laptops. Smart devices, nest, ring, hue, Rachio, etc. Amazon fire TV's, game players.
Not sure what top speed I should see but highest has been mid 300mpbs upon first install. Now I'm lucky to see 40mbps. I haven't changed any default settings. Xfinity has walked me thru multiple resets on my modem and I've powered cycled Orbi a few times. Sometimes I see increased speeds but shortly drops back down.
Typically have 32-35 devices connected, 7 hardwired, 4 on router, three on upstairs satellite.
Sometimes wifi is so bad steaming stops and kids go nuts. Literally woke up by one rug rat at 11pm to tell me Wi-Fi stopped working.
Xfinity has been zero help and they want me to use their equipment. They are coming out tomorrow too test lines.
Saw previous past about beam forming and other mu-mimo settings. Both are off for me. Checked firmware and I'm on latest 2.0.0.74.- DarrenMOct 23, 2017Sr. NETGEAR Moderator
You may want to enable beamforming and mumimo that was a issue with really old firmware and was fixed and some people have had better performance with it on.
DarrenM
- rgadueOct 23, 2017Aspirant
I tried that with tech support and speeds went down. However, I had Comcast come out this weekend and they found a bad connection and repaired. Speeds are much more consistent now. I'm doing about 300 mbps over wifi and curious how to get the 866 for my newer devices on the 5ghz. Wired I'm getting over 900mbps. I have the gig service w/ comcast. I have tried enabling those settings since the repair. Any other settings I may want to check?
DarrenM wrote:You may want to enable beamforming and mumimo that was a issue with really old firmware and was fixed and some people have had better performance with it on.
DarrenM
