s22tran
Sep 20, 2017Aspirant
Orbi SSID not appearing
I have an Orbi RBK50. When I turn on my router and satelite, the SSID does not appear on my network list. The pin hole reset button is initially unresponsive as well and after a while (more than 5 mi...
DarrenM
Sep 22, 2017Sr. NETGEAR Moderator
Hello s22tran
Are you able to log into the orbi using the ethernet cable and change the SSID?
DarrenM
