85percent
Nov 05, 2017Follower
Orbi, still disconnecting
- I just bought this Orbi system, and I installed the very latest software on both the router and the satellite. Every 45 minutes or so, the satellite turns magenta and I lose internet signal. The satellite is literally 20 feet away from the router. I check the router when this happens, and it also loses internet connection as well. How do I solve this? Before I decide
to return it?
- Retired_Member
Move it closer. Yes, 20 feet is close, but it may need to be 15 or 10 or 1 after the 2.0.x release.
This should not have to be closer. 20ft? C'mon. I know you are being snarky but this thing should have some range.
And yes, I'm having the same issues, for the last month, and it's been infuriating.
- Retired_MemberSeriously not being snarky. I had to move mine from about 40 ft to 15 and 20 for my two sats.
