Zaichik's avatar
Zaichik
Orbi stopped working with ethernet switch
Hi,
I have an Orbi RBK50 system with 2 satellites. Some devices are connected to the router using ethernet and a Netgear GS308 unmanaged ethernet switch.
Until yesterday, everything worked fine. Now, however, devices connected via the switch don't receive an IP address from the router and thus cannot connect to the network. The devices can detect they are connected by ethernet, but that's as far as it goes. If I connect them directly to the router via ethernet or WiFi, they can connect fine.
I have not changed any of the settings in the router or any of the devices and the router is running the latest firmware.
I have tried:
Replacing the switch
Changing the ethernet cables
Factory resetting the Orbi system
None of these have fixed the problem.
I'm out of ideas and call upon the wisdom of the community in the hopes of a solution.
Thanks in advance for any help.
  • My first thought would be the switch. But since you swapped out the switch with a known working switch, I would now check the cable coming from the Orbi to the switch.
    • Zaichik's avatar
      Zaichik
      Thanks. I've tried changing the ethernet cable with a couple of others that I know work elsewhere in the house. Still no dice.
      • Mstrbig's avatar
        Mstrbig
        Master
        What happens when you bypass the switch and plug one device's cable directly to the Orbi?
