Zaichik
Sep 06, 2020Aspirant
Orbi stopped working with ethernet switch
Hi, I have an Orbi RBK50 system with 2 satellites. Some devices are connected to the router using ethernet and a Netgear GS308 unmanaged ethernet switch. Until yesterday, everything worked fine....
Zaichik
Nov 12, 2020Aspirant
Thank you for your helpful messages. Sorry for only coming back to this now. I got another of the 308 switches and, until today, it's been working fine, but now devices connected to it can connect to the Internet, but they can't connect to any onward services like PlayStation Network, Xbox Live or Netflix. Again, if I connect them directly to the Orbi router using the very same cables, all is fine.
Given the comment above about certain brands or types of switches having issues with Orbi, is there any particular model or brand that is known to be reliable?
Nov 12, 2020Guru - Experienced User
NG GS-105/108v4, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
- ZaichikNov 12, 2020AspirantThanks, I'll look at one of those models and see if they work any better. I can't believe that a Netgear switch doesn't work with a Netgear router.
What were the issues that were reported with the green switches? Were they similar to what I am getting? - FURRYe38Nov 12, 2020Guru - Experienced User
Ya Green Ethernet features seems to cause problems for some.
What FW version are you using on the Orbi system?
History...
Green Switch: https://community.netgear.com/t5/Orbi/switching-requirements-for-ethernet-backhaul/m-p/1653718/highlight/true#M43817
https://community.netgear.com/t5/Orbi/Ready-to-chuck-this-system-through-the-window/m-p/1658470/highlight/false#M44394
https://community.netgear.com/t5/Orbi/Orbi-AC3000-with-Cisco-SG112-24-Switch/m-p/1700690/highlight/true#M51879
https://community.netgear.com/t5/Orbi/Orbi-Netgear-GS908E-100PES-Backhaul-Connection/m-p/1784425/highlight/false#M67633
https://community.netgear.com/t5/Orbi-AX/RBR850-Access-Point-wired-backhaul-amp-security-issues/m-p/1868322/highlight/true#M1498
Working with Green Switch:
https://community.netgear.com/t5/Orbi/Orbi-AP-mode-and-Backhaul-connections/m-p/1966334/highlight/true#M101265
