BrookHampton's avatar
BrookHampton
Orbi stopped working
Came home today to no wi-fi. Or I blinking white, power led blinking red. No wifi broadcast. Reset Orbi - no difference. No wifi broadcast. Tech support was tedious trying to log in on a poor cell signal. Half hour later says my 90 day warranty expires September 1st.
I have no laptop here, Just ipad and iphone.... Suggestions.
BTW - my netgear experience has been horrible, right down to posting this thread. Keeps asking me to fix the highlighted items...
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello BrookHampton
    The light flashing red means the firmware is corrupted you may need to try a factory reset by holding the reset button for 10 seconds and then see if you can set up your orbi again. If not you will have to contact support.
    http://www.netgear.com/support/contact.aspx
    DarrenM
