bheld
Feb 15, 2019Aspirant
Orbi struggling to get IP address/DNS from fixed wireless ISP
I'm replacing my Asus router (RT-N66YU) with this RBR50 unit. I live in a rural area and use fixed wireless service from my ISP (a 2.4 GHz line of sight system). This means there is a radio (powered ...
- Feb 18, 2019
bheld wrote:
Unforutnately neither of these helped. Log:
When you tried the router's MAC address cloning or "use this MAC", have you rebooted Orbi and the radio eqipment then?
Some ISP's remember the MAC address of the first router and does not accept any other request from other MAC addresses (for security reasons). Since you had the ASUS working earlier, so this is a good troubleshooting step to make sure is tested.
ekhalil
Feb 15, 2019Master
bheld wrote:
......... This means there is a radio (powered with power over ethernet) on my roof that communicates with my ISP.
Which Ethernet is power feeding the radio?
- bheldFeb 15, 2019Aspirant
The POE unit is new (ISP replaced just in case) - this did not help.
- ekhalilFeb 15, 2019Master
Ok, but where is the Ethernet cable that is feeding the POE unit coming from?
Do you have any link to the radio unit product description?
It's quite simple - the radio is on a mast on my roof. An ethernet cable feeds that from the POE. The other jack on the POE runs directly to the Orbi.
I have no details on the radio. ISP claims that they have other customers on Orbi, but I don't necessarily believe them (long history). They are my only option.
