bheld's avatar
bheld
Orbi struggling to get IP address/DNS from fixed wireless ISP
I'm replacing my Asus router (RT-N66YU) with this RBR50 unit. I live in a rural area and use fixed wireless service from my ISP (a 2.4 GHz line of sight system). This means there is a radio (powered ...
  • ekhalil's avatar
    ekhalil
    Feb 18, 2019
    bheld wrote:
    Unforutnately neither of these helped.  Log:
    When you tried the router's MAC address cloning or "use this MAC", have you rebooted Orbi and the radio eqipment then?
    Some ISP's remember the MAC address of the first router and does not accept any other request from other MAC addresses (for security reasons). Since you had the ASUS working earlier, so this is a good troubleshooting step to make sure is tested.
