Support_Sucks
Jul 09, 2020Aspirant
Orbi suddenly doesn't allow sites, even irs.gov
Bought Orbi system in December and it has worked well, but suddenly doesn't allow random sights that it didn't limit before. One of the sites is even irs.gov to pay our quarterly taxes. Called Netg...
Jul 09, 2020Guru - Experienced User
IF the sites had been working before and you haven't made any changed to orbi since installing it, it would NOT be Orbi that is blocking web sites.
Do you have Armor or Circle enabled?
Support_Sucks
I directly connected the ethernet cable from my laptop to the modem and had no issues loading the sites. When I disconnect my phone from the wi-fi and load the sites I don't have any issue either. But if I use wi-fi on either my laptop or phone I have issues.
Circle wasn't enabled. Armour has been enabled since we installed the router back in December and we've never had any issues with it. I turned that off and am still not able to get on those sites.
Updated my Orbi firmware and still not having any success with those sites.
- FURRYe38Jul 09, 2020Guru - Experienced User
Try a factory reset on the RBR and setup from scratch again. I would power OFF the ISP Modem for 30 seconds as well while you factory reset the RBR. Be sure not to enable Armor or Circle as well.
- Support_SucksJul 10, 2020Aspirant
It's a Spectrum modem from Hitron Technologies, Inc. Model E31N2V1
I'll have to try the factory reset. Hopefully that works. I appreciate you continuing to try to help me with this!
- FURRYe38Jul 10, 2020Guru - Experienced User
Let us know how it goes.
I would also reset or power OFF the ISP modem as well for 1 minuted then back ON while the RBR resets.
- Mikey94025Jul 11, 2020Hero
Support_Sucks wrote:I directly connected the ethernet cable from my laptop to the modem and had no issues loading the sites. When I disconnect my phone from the wi-fi and load the sites I don't have any issue either. But if I use wi-fi on either my laptop or phone I have issues.
Sorry to hear that factory reset didn't help you. Please post a picture of the exact error message/screen from your laptop, ideally from two different browsers. The exact error message you're getting might help us diagnose what is going on here because your experience not being able to access only specific websites is unusual given that Circle and Armor are both disabled.
Is your problem perhaps the same as https://community.netgear.com/t5/Orbi/Orbi-Blocking-Websites-Solved/td-p/1677125 ?
- FURRYe38Jul 11, 2020Guru - Experienced User
What version of FW is currently loaded?
Can try v32 if you haven't already updated:
