essentR
Oct 22, 2017Follower
Orbi support for TP-Link wired Access point?
I"m looking at RBR50 (not RBK50). Trying to decide on Orbi mesh system to upgrade. I need a system that will allow me to use a wired access point for a guest house. The system would be (all via ...
DarrenM
Oct 24, 2017Sr. NETGEAR Moderator
You should be able to hook up the AP to the orbi but you will create a separate wireless network.
DarrenM
