essentR
Oct 22, 2017Follower
Orbi support for TP-Link wired Access point?
I"m looking at RBR50 (not RBK50). Trying to decide on Orbi mesh system to upgrade. I need a system that will allow me to use a wired access point for a guest house. The system would be (all via ...
Slosh104
Apr 07, 2018Aspirant
One issue that you might have is that most TP Link products can only run on 2.4GHz. The Orbi might put it on the 5GHz and while it will integrate with Orbi, you might not be able to add The TP Link as a skill on Alexa.
