Elvisj
Jan 17, 2017Star
Orbi switch connection
I have the Orbi router and three satellites. I need to connect three 24 port switch boxes to the network. Must I connect the switches to the router or can I connect a switch to each satellite?.
Sort By
- st_shawMaster
That's a lot of switch ports. If you connect a wired device to the satellite, it will communicate to the router over the dedicated 5 GHz WiFi backhaul. I have benchmarked this link at 500 Mbps throughput, as have others on this site. A Gigabit Ethernet switch will provide ~990 Mbps throughput on each port.
The answer to your question depends on what you are trying to do, and which devices need to talk to which. But, if you want the devices connected to the switches to have the fastest throughput to/from the Internet (990 Mbs instead of 500 Mbps), then you would be better off connecting your switches to the router.
Thanks, I have a 6,000 sf house and have widely distributed TVs, music, cameras and phones, which is why I spread 3 24 port switches within the house. Not all are full, but I like a port available when needed. I doubt speed is critical so I will test moving the switches to satellites, because running long ethernet wires across the attic from one router is difficult.
- st_shawMaster
That's a large area to cover. It sounds like you already have the three switches installed and wired back to a router. Is that the case?
- cue003Apprentice
Just to be clear from your last post... you have an Orbi router PLUS three (3) or is that four (4) satellites? And it is all working pretty well -- except one on the external garage?
This will be the most amount of satellites that I heave read about yet on this or any other site.
Where is the router in relation to all the satellites? Center of house, corner, etc.
