rwd2001
Sep 02, 2025Aspirant
Orbi System causing issue with EPSN app
Hello, I have an RBR50 with multiple satellites that has worked flawlessly for years. However, now with the latest crack downs on VPN's etc. I am having issues with certain apps, specifically r...
- Sep 02, 2025
On the RBRs web page under Advanced Tab/Setup/Internet Setup, down this page there is a DNS section, will be set to auto, can set to manual and then you can input different DNS, Try 9.9.9.9 and 149.112.112.112.
Also if these are the only apps having issues and others do not, you should contact the mfr of these apps as well. Possible changing in there operation at the Mfr level maybe involved as well.
May need to factory reset the system then setup from scratch as another troubleshooting step.
CrimpOn
Sep 02, 2025Guru - Experienced User
rwd2001 wrote:The ESPN app for refence would not work
In what way does the ESPN app not work? Is there an error message?
rwd2001
Its acts as if I am not within a region that it can access when I am connected to the WiFi. Works fine when straight to my fiber connection or on cellular
data.
- FURRYe38Sep 02, 2025Guru - Experienced User
Ya thats not a Orbi issue.
Whos your ISP and
What brand and model# is the ISP modem or ONT the RBR is connected too?
Try using different DNS services, i.e. cloudfare or quad9.
- rwd2001Sep 02, 2025Aspirant
Appreciate your help, but again, if i bypass the orbi system and go straight to the ONT, or turn wifi off on my phone then those devices work.
