almandr
Jan 19, 2018Follower
Orbi System Functionality with GoGoGate2
I have an Orbi network that I have been using very successfully for several months. I received a GoGoGate2 to make my garage door smart for Christmas. While attempting to install this device I am conj...
bobpar1
Jan 28, 2018Aspirant
I had the exact same issue and was never able to get the Gogogate 2 to connect to the Orbi router. I tried to turn off the satelite so that it would force a 2.4GHz connection but it did not resolve the issue. I eventually gave up and turned on my Comcast Wifi to get it to connect and it worked fine. I would much rather use the Orbi to connect and turn off the Comcast wifi router so that it does not interfere with Orbi but until there is a way to connect the Gogogate 2 to the Orbi router I will have to live with this workaround. Any suggestions would be appreciated. Netgear needs to find a way to provide connectivity to IOT devices that require 2.4GHz with Orbi (and not force users to hack a solution).
