fbell
Oct 04, 2018Aspirant
Orbi TLS 1.0
Set up PRTG network monitoring on my laptop to try and get to bottom of network issues. The SSL Security Check sensor has found that TLS 1.0 (Weak) is still being accepted by the Orbi router and satellites. Is this something that can be configured/turned off? If not, are there any plans to retire the older TLS protocols in a future firmware update?
It probably doesnt matter in a home network environment but may as well address the issue if not explicitly required...
