zeege
Oct 09, 2018Aspirant
Orbi Topology
Hi All,
I have a question on Orbi topology. To my understanding the default topology would be as in picture one where I have to do double cabling if I want to use ethernet backhaul to connect to Sa...
Oct 09, 2018Guru - Experienced User
If you already have a router in place, you can use the Orb system in AP mode, where the base becomes the main wireless AP and controller for the satellites. You can still wire connect the satellites to the Orbi base for wired backhaul as well in AP mode.
- zeegeOct 09, 2018Aspirant
Is there some instructions on cabling for this setup? I assume on the Orbi Router I only connect Ethernet port to the switch that I have and connect the other Orbi satellites to the same switch?
- FURRYe38Oct 09, 2018Guru - Experienced User
Yes you can connect the satellites to the same switch with the main Orbi base. Or have a switch in between the base and satellites.
What is the Mfr and model# of the ethernet switch? Managed or non Managed? There are known problems with Managed switches and Orib systems on wired backhaul. Mainly IGMP protocols.
So you are saying that the Topology picture #2 would work assuming my router would provide DHCP and other needed functions. Orbi Router + Sattellite would work as Plain APs that would work in a MESH? I am using an HP 1810-8G(J9802A) switch but it seems that it does not support Layer 2 Multicast (IGMP) snooping. I see no problem in updating the switch as long as don't need to do extra cabling.
