Maroman
Mar 26, 2019Guide
Orbi Traffic meter and Daylight savings
The traffic meter feature in the Orbi only works if you disable daylight savings time. That works but for some reason daylight savings becomes enabled again then the traffic meter stops working again....
Mar 28, 2019Guru - Experienced User
NG seems to be aware of this. Hopefully NG will get this fixed soon or in the next FW roll out. Please be patient.
neerajv
Mar 31, 2019Tutor
Well, looks like 1+ year is a good enough time to be patient.
Looks like netgear is aware of the issue but has done nothing since last 1 year. Have a look at below post that was created in Mar 2018 for exact same issue.
-Neeraj
