Maroman
Mar 26, 2019Guide
Orbi Traffic meter and Daylight savings
The traffic meter feature in the Orbi only works if you disable daylight savings time. That works but for some reason daylight savings becomes enabled again then the traffic meter stops working again....
neerajv
Mar 31, 2019Tutor
Well, looks like 1+ year is a good enough time to be patient.
Looks like netgear is aware of the issue but has done nothing since last 1 year. Have a look at below post that was created in Mar 2018 for exact same issue.
-Neeraj
Maroman
Mar 31, 2019Guide
I had a 2 hour call with tier 2 support investigating on Friday. Hopefully they find something.
- FURRYe38Mar 31, 2019Guru - Experienced User
Thanks for letting us know. Hopefully they will get it fix on next FW date. Maybe sooner hopefully.
Users can revert to v210 if TM is needed.
Maroman wrote:
I had a 2 hour call with tier 2 support investigating on Friday. Hopefully they find something.- neerajvMar 31, 2019Tutor
So once we go to older version, wouldnt it auto update to newer version?
Why does NG doesnt give any ETA on this. It's an year old issue, do they not care about the customers? They expect customers to perform these workarounds. Who knows what all issues might be there in .210 , so this workaround will just make us dance between one firmware to another.
-Neeraj
Also, just some additional information. The Daylight saving gets checked back the moment you open an iOS app.
-Neeraj
