aruit
Dec 11, 2016Guide
Orbi turns Magenta after some days working OK
I have the Orbi system for two weeks and they are working well most of the time. After installation the Orbi Satellite turned Blue and was working OK for several days. But suddenly I found the O...
- Jan 17, 2017
Hello Darren,
My Netgear Orbi is now running without the solid Magenta light problem, so this problem is really solved with firmware 1.4.0.34.
Thank you for the support,
Anton
bsholbrook
Jan 03, 2017Apprentice
Same solid magenta on satelite, in this case the system ran for 10+ days and then the issue came up.
aruit
Jan 17, 2017Guide
Hello Darren,
Anton
