aruit's avatar
aruit
Guide
Dec 11, 2016
Orbi turns Magenta after some days working OK
I have the Orbi system for two weeks and they are working well most of the time.   After installation the Orbi Satellite turned Blue and was working OK for several days. But suddenly I found the O...
  • aruit's avatar
    aruit
    Jan 17, 2017
    Hello Darren,
    My Netgear Orbi is now running without the solid Magenta light problem, so this problem is really solved with firmware 1.4.0.34.
    Thank you for the support,
    Anton
