Yamster2016
Sep 09, 2018Aspirant
ORBI UPNP Issue
Hi,
I currently have BT VDSL and I am having issues with Upnp. I have a bt modem connected to my orbi which is dialing the PPPOE details. I have upnp turned on but nothing is showing in the upn...
Sep 10, 2018Guru - Experienced User
What FW is currently loaded?
How is the console connected tot he Orbi? Wired is preferred...
What browser are you using to check the Orbis UI?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
