Yamster2016
Sep 09, 2018Aspirant
ORBI UPNP Issue
Hi,
I currently have BT VDSL and I am having issues with Upnp. I have a bt modem connected to my orbi which is dialing the PPPOE details. I have upnp turned on but nothing is showing in the upn...
beastlove
Nov 20, 2018Aspirant
Did you sort this?I am having the same problem.
- FURRYe38Nov 21, 2018Guru - Experienced User
What FW is currently loaded?
How is the console connected tot he Orbi? Wired is preferred...
What browser are you using to check the Orbis UI?
