beastlove's avatar
beastlove
Orbi UPNP Portmap Table Blank
Hi
I am having some trouble with my sons PS4 and NAT. It comes up with a message that voice chat will not work due to his NAT settings and I think it might be something to do with UPNP
I'm no expert on networking so could do with some help. We have 2 x PS4 console in the house. One is hardwired to the Orbi satellite which in turn is hardwired to the main Orbi router. We got a second PS4 last month and this is now hardwired into the Orbi Router.  The first PS4 works fine but the second has the voice problems due to NAT (not all the time though). I checked the UPNP settings and could only see the IP address of the first PS4. I refreshed the page, disabled and enable UPNP and now the table is blank. I am not sure if it should be blank or not. Really cannot understand why one works and the other doesn't. I am on the latest firmware as well. Please help
Thanks
  • FURRYe38's avatar
    What FW is currently loaded?
    If you have to game consoles on the same network, do the following. Set up IP address reservations for each console. Save settings and apply and turn OFF the game consoles. Go in and set NAT Filter to OPEN. Save settings and apply. Found under Advaned Tab/Setup/WAN Setup.
    • beastlove's avatar
      beastlove
      I am running firmware V2.2.1.210.
      What is the Mfr and model# of the ISP modem the NG router is connected too?  BT standard - ECI Telecom Ltd, B-Focus V-2Fub/r rev B.
      I've set static IPs for both consoles. Is it not dangerous to have Open NAT?  I have my PC, laptops etc on the same network. As much as I love my son playing video games, I don't want to become the victim of internet fraud or getting a virus. Happy to have open nat for both consoles if that helps.
      • FURRYe38's avatar
        This modem have a built in router? Just checking as if it does, this can cause problems. I believe it's a modem only.
        Type 2 what you should see on PS game consoles. It will be the max you will ever see with a router behind a stand alone modem with out a built in router.
        Having OPEN for NAT Filter is ok. It works for multi player games and some NAT issues with two or more game consoles behind the same router. You can keep Secure as well. NAT Filter mostly effects mutliplayer games like CoD with two or more game consoles. If you or your son don't play these kinds of games, keep Secure. I play CoD games and have two consoles playing same game at the same time so I use OPEN. No issues.
        What browser are you using? Does IE11, FF or Opera browser see this issue.
        Please post a picture of what your seeing in the uPnP table for review...
  • beastlove wrote:
    ........... I checked the UPNP settings and could only see the IP address of the first PS4. I refreshed the page, disabled and enable UPNP and now the table is blank. I am not sure if it should be blank or not. Really cannot understand why one works and the other doesn't. I am on the latest firmware as well. Please help
    It seems that the PS4 is not making the UPNP requests. One way to force the PS4 to make the UPnP requests can be to run the "Internet Connect Test" in PS4. Please try this if the above proposal from FURRYe38 does not work
      beastlove
      Thanks for the suggestion. I tried what you recommended about it doesn't seem to show anything in the UPNP table. Both consoles are showing NAT Type 2 which would suggest it is working but the lack of voice chat shows it doesn't.
      • FURRYe38's avatar
        I beleive your modem has a built in router already.
        Modem Combo Units:
        Couple of options,
        1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
        2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
        3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
        Have you tired disabling any uPnP on the modem.
        Try the Orbi in AP mode wit the modem?
  • FURRYe38's avatar
    Ok, lets try this. set up IP address reservations for the both consoles ON the router. I would wired connect the consoles for this. If you choose wireless, you'll may need to set a different IP address reservation for the wireless connection. Clear any static IPs on the consoles and set them up for dynamic or auto obtain IP/DNS addressing. If Sony has any kind of power button reset method to reset the consoles, lets do that and fully power them OFF. For xbox, if you hold the power button untill it shuts off, this clears it's caches using this method.
    Besure uPnP is enabled and NAT Filter is set to OPEN on the router. Save settings and then power OFF the Modem and Orbi router. Power ON the modem and let it sync. Then power ON the Orbi router. Let it come to ready.
    Power ON the sons console first. Check NAT status with in the consoles networking settings. I presume it has this some place. I don't use PS so Just kind of going on what Xbox has. I presume you should see NAT Type 2 here. This is fine. Launch his game and check for any NAT status or check the chat condition.
    Power on your game console and check NAT status on the console. Then start your game and check status here.
    If all is cleared, there shouldn't be any problems getting into games and chat should work.
      beastlove
      Thanks FURRYe38 . Voice chat is working now but the UPNP table is still blank. Doesn't really much difference but still odd none the less. I am guessing this must be a firmware bug or something.  Thanks to all for the help and advice.
      • FURRYe38's avatar
        Possible issue in FW. You should make contact with NG support about this. Hopefully some engineering review will be done.
        Blanca_O
