Yamster2016's avatar
Yamster2016
ORBI UPnP Xbox One Issues
Hi Guys,
I have having lag issues and I think it's due to ports not being opened correctly. When I check the router i can see the following port is being used 3074 but what i dont understand is no other ports are being used.
If I check which ports fifa uses then I would have expected all the ports the game requires would be in the UPnP section??
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Have you done all the port forwarding for xbox or try putting the xbox in the DMZ?
    DarrenM
