OPRF
Jan 04, 2017Initiate
Orbi USB Firmware?
Hi, are there any plans to update the firmware on the ORBI to allow us to use the USB port to connect a printer? I just switched to ORBI from an Apple Airport Extreme for better wireless coverage, b...
rhester72
Jan 05, 2017Virtuoso
OPRF wrote:Any know when this will be available? I can live with a crappy interface, but the USB port was the reason I went with this unit over others.
It was? I thought it was well-understood on these forums (you did research the product before purchase, right?) that there was no USB device support, nor is it mentioned anywhere on the packaging or documentation.
Rodney
- OPRFJan 06, 2017Initiate
Thanks for the *helpful* reply Rodney.
The packaging highlights a USB port, and the documentation is basic on how to connect to the internet and the satellite. I did read reviews of the product which mentioned the interface challenges, but none mentioned the USB port was only a decoration. I only turned to the form when I couldn't find information elsewhere.
I was hoping (as it appears there are Netgear employees on this site) for an answer.
- MarkC1024Jan 06, 2017Luminary
I would agree that as the product data advertises USB 2.0 support, it should be functional. However, USB 2.0 is pretty slow and you're much better off getting something ethernet based that is designed to function as a cloud device. It will perform much better.
- rhester72Jan 06, 2017Virtuoso
Right now, the only thing the USB does is allow you to dump logs to a flash drive in debug mode. As Netgear is unlikely to announce future plans on a forum, I wouldn't expect much in the way of any sort of official forward-looking answer.
Rodney
