russellmoran99
Nov 10, 2016Luminary
Orbi using Uverse and Slingbox 500
I have an Orbi system behind a Uverse Motorola NVG589. I have read the directions and turned my Uverse modem into bridge mode as much as allowed. (see here) I am not 100% I have done it correc...
russellmoran99
Correct, my Uverse is set to 192.168.2.X and my Orbi is 192.168.1.X. According the link I posted above, that's what I believe it told me to do. Am I incorrect?
peteytesting
Nov 10, 2016Hero
if you upostream device is bridged why are you setting the orbi to a static ip address ? in most cases even if you have a static ip address with your isp you still use dynamic ip on the wan connection as the ip address you get is just reserved at the isp
