IronAddict
May 20, 2018Aspirant
Orbi Verizon’s Fios and MoCA
I just ordered the Orbi AC2200 to alleviate dead spots in my house. I currently have some devices connected using MoCA i.e. basement, and I’m curious to know if I can still utilize MoCA after I set up...
- May 21, 2018
Turn off the wireless in the Verizon router and set the Orbi to AP mode and ethernet cable connect the two. You lose some functionality in the Orbi but it prevents the double-NAT scenario, which can be troublesome. For instance the devices on the MoCA network won't be on the same network as the Orbi which means they probably can't talk to each other.
The Verizon router should still be configured to hand out the IP addresses. I have this setup currently and it works well (except for Homekit on the last iteration of auto-updates and Ring Doorbell).
Go to dslreports.com and check out if your VZ router has a bridge mode or not. Bridge mode could allow the Orbi to perform all normal router functions (not be in AP mode). I'm still on an Actiontec MI424WR which doesn't support Bridge mode.
I will say that Orbi's wireless range is fantastic. I have great WiFi coverage in an almost 100 yo house and 100 ft range in the back yard.
usahale
May 21, 2018Star
- IronAddictMay 21, 2018Aspirant
Ushale,
I set up Orbi as an AP as you described and everything works thanks! Following that, I looked up my router Greenwave FiOS-G1100 on dslreports.com and it doesn't look like it supports bridge mode 😒.
Some things I notced after set up:
- I can't login into admin page for Orbi (bummer because I liked it)
- Reduced speeds for devices connected to Orbi Satellites via ethernet (I'm constistently getting 20Mbps out of 100/100).
- usahaleMay 21, 2018Star
Definitely odd. You've got a better VZ router than me and I get consistent 50+MB out of my wireless connections. I don't have any wired to my Orbi Sat, though. Are the Sats wireless backhaul or wired? I'm wireless backhaul, 2 floors apart, so 20 ft with 2x10 floors (or plaster ceiling depending on your view) between the router/sat. Is the router ethernet connect to the yellow (Internet) port? And orbilogin not working, that's odd. Have you tried direct ip address to your Orbi router? You should be able to see the Orbi's address in the VZ router network map.
