IronAddict
May 20, 2018Aspirant
Orbi Verizon’s Fios and MoCA
I just ordered the Orbi AC2200 to alleviate dead spots in my house. I currently have some devices connected using MoCA i.e. basement, and I’m curious to know if I can still utilize MoCA after I set up...
- May 21, 2018
Turn off the wireless in the Verizon router and set the Orbi to AP mode and ethernet cable connect the two. You lose some functionality in the Orbi but it prevents the double-NAT scenario, which can be troublesome. For instance the devices on the MoCA network won't be on the same network as the Orbi which means they probably can't talk to each other.
The Verizon router should still be configured to hand out the IP addresses. I have this setup currently and it works well (except for Homekit on the last iteration of auto-updates and Ring Doorbell).
Go to dslreports.com and check out if your VZ router has a bridge mode or not. Bridge mode could allow the Orbi to perform all normal router functions (not be in AP mode). I'm still on an Actiontec MI424WR which doesn't support Bridge mode.
I will say that Orbi's wireless range is fantastic. I have great WiFi coverage in an almost 100 yo house and 100 ft range in the back yard.
May 21, 2018Guru - Experienced User
You can also use the DMZ on the VIOS modem if it can't be bridged if you want to use the Orbi router as a router.
- IronAddictMay 21, 2018Aspirant
Furrye38,
That sounds like an interesting set-up, care to share what you changed on your VZN router?
- FURRYe38May 21, 2018Guru - Experienced User
If the modem can't be bridged, set up a IP address reservation on the modem/router for the IP address the Orbi router gets from the modem while the Orbi is in router mode.
Input this IP address into the modems DMZ. Since the Orbi router has a firewall as well, it's safe to use the DMZ on the modem. It's no different then having a stand alone modem with out a router built in. The Orbi router will handle the firewall issues on it's own.
Then you can use the Orbi router in router mode and it can be your main host router. DMZ will help in this double NAT condition.
I would also disable ALL wifi radios on the modem and uPnP.
Connect up all your devices to the orbi system.
Thats all.
IronAddict wrote:
Furrye38,
- DarrenMAug 03, 2018Sr. NETGEAR Moderator
Here are some helpful guides and KBs that will help you get you Verizon orbi system up and running.
https://www.verizon.com/cs/groups/public/documents/adacct/orbi-install-guide.pdf
DarrenM
