Maumentum
Jan 02, 2017Tutor
Orbi vlan + wireless printer via usb
Will the USB port on the Orbi router or Orbi sattelite support wireless printing via plugged in printer very soon? Also why does the Orbi not support vLAN tagging out of the box, which has me hoping ...
DarrenM
Jan 05, 2017Sr. NETGEAR Moderator
Hello Maumentum
As of right now the USB is for future use.
DarrenM
- MaumentumJan 28, 2017Tutor
Thanks DarrenM but what about vLAN tagging, will the Orbi ever support this? All my Vodafone fibre connection needs is vLAN tagging on Orbi
- DarrenMFeb 03, 2017Sr. NETGEAR Moderator
VLAN tagging is on the road map but we currently don't have an ETA as its not high priority at this time. In the next firmware release we will add VLAN bridge on the routers LAN port only for ISP in Singapore. This may work for you as long as his ISP use same config as ISPs in Singapore.
DarrenM
