Retired_Member's avatar
Retired_Member
Jun 04, 2019
Orbi Voice, volume controls (slider on top & voice command "Alexa volume up/down) do not respond
The volume controls on top of the Orbi Voice stop working, vol control slider on top lights up and move left and right, and voice command to change the volume have no effect. Volume stays the same. Can change the volume via the Alexa cell app but not by voice control or top light slider.  Power failing the Orbi Voice fixes it for a while then the problem reoccurs.  I think it's a firmware issue, because the volume can be changed via the Alexa cell phone app 100% of the time.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Retired_Member
    Welcome to NETGEAR Community!
    - May we please know the firmware version of the router and satellite?
    - What version is the Alexa app and Orbi app?
    - Are there other services affected aside from the volume control?
    Blanca
    Community Team
  • Blanca_O's avatar
    Blanca_O
    Hi Retired_Member
    We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
    Blanca
    Community Team
    • sctybones's avatar
      sctybones
      Initiate
      The volume controls stopped working on top of the satellite speaker can someone help. No sound comes out or it’s really really soft. Firmware v2.3.5.14
      • industrial's avatar
        industrial
        I have same issue, but with the added bonus that Alexa app cannot change the volume either.
