kornholio64
Feb 21, 2019Aspirant
Orbi VPN for Smart TV Orbi RBR50
I have an Orbi RBR50 and I'm trying to use the VPN for my Roku box (mainly to watch Netflix), but I can't seem to make it work.
kornholio64
Feb 22, 2019Aspirant
Please see the image, I'm asking for the VPN settings that the Orbi has in the advance options
- ekhalilFeb 22, 2019MasterThe VPN settings in Orbi allows you to use a computer or a smart phone to establish a VPN tunnel from outside your home via internet to your Orbi at home so you can access the home devices as if you are at home.
The Roku is attached to your home Orbi so you can use a smart phone to connect a VPN to your home while you’re outside to be able to use the Roku as if you’re at home.
Is this what you want?
