pjhacker
Sep 26, 2018Aspirant
Orbi VPN no network access
Hi,
I have setup my Orbi DDNS using the Netgear built in DDNS. I enabled the VPN service. I installed and configured OpenVPN on my Windows 10 machine. I can connect to my network just fine with the OpenVPN client. I am NOT able to access any server/resource on my network. I had this working at one point and it stopped working. I was able to RDP to my servers and access my network. I am not sure why it stopped working, but I just cannot RDP to my servers anymore. Like I stated the connection is fine. It has a correct IP address assigned to the NETGEAR-VPN adapter and uses the right Gateway IP. I have uninstalled and reinstalled OpenVPN. I have deleted the configuration and reconfigured OpenVPN. Everything appears to be fine, just no network access. Can anyone think of a reason why it may not be working anymore?
Thanks in advance,
Paul
- Retired_MemberSep 27, 2018
I had a similiar issue until I changed the "Clients will use this VPN connection to access" option. By default mine was on AUTO which worked for a few days then stopped. I changed it to "All sites on the Internet & Home Network" and it started working again.
- Retired_Member
