ATC1125
Jul 25, 2018Follower
Orbi w/ AT&T Fiber
I am looking to switch to AT&T fiber. I currently have xfinity internet for which I use my orbi system. AT&T representative said there would be no benefit to using the orbi with their fiber. Is that c...
- Aug 08, 2020Putting my Orbi in AP (Access Point) mode and turning off the WIFI on the Arris worked a charm. No more problems.
waynealight
Jul 25, 2018Apprentice
the benifits of using orbi is for coverage and features. att router doesn't support upnp. you will be able to create a pass through for the orbi using dmz plus. This will allow the orbi to have a wan address and not just a lan address from the att router. if att pushes an update to the router it will reset this feature and you will have to reenable it. only happens a few times a year. if you dont do this you will create a double nat situation and have issues connecting to some devices using upnp.
