ATC1125
Jul 25, 2018Follower
Orbi w/ AT&T Fiber
I am looking to switch to AT&T fiber. I currently have xfinity internet for which I use my orbi system. AT&T representative said there would be no benefit to using the orbi with their fiber. Is that c...
- Aug 08, 2020
Putting my Orbi in AP (Access Point) mode and turning off the WIFI on the Arris worked a charm. No more problems.
Jul 25, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode. DMZ helps wtih double NAT conditions in this case.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
Orbi Wifi would be far superior to anything that ATT has on there modem/ONTs.
- mpf541Jul 25, 2018Apprentice
I have att fiber and orbi. It works great but nyou need to get the right gateway. You do not want to use DMZ with this. What you want is IP passthrough. Set it up with this and the orbi works great.
Make sure yo tell thgem this is what you want. Specify a gateway with IP Passthrough. You can request it and they will ship one.
They do have more bthan one model but this arris i have is the latest. At least when i got it the beginning of them year.
My att gateway is
Manufacturer ARRIS Model Number BGW210-700
- bvg820Nov 27, 2018Aspirant
I have the same setup. Will you be so kind as to let me know what you did to accomplish this?
Thanks!
- FURRYe38Nov 27, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here?If so, Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Thanks!
- viperxln1May 19, 2019Aspirant
I have an Orbi as well but trying to get it to work with BGW210-700. Can you walk me through by specifying a gateway with IP Passthrough?
Thanks
- AmitctrJun 04, 2019TutorWhat settings did you use with your gateway? I have the same model but can’t get it configured correctly.
