ATC1125
Jul 25, 2018Follower
Orbi w/ AT&T Fiber
I am looking to switch to AT&T fiber. I currently have xfinity internet for which I use my orbi system. AT&T representative said there would be no benefit to using the orbi with their fiber. Is that c...
- Aug 08, 2020
Putting my Orbi in AP (Access Point) mode and turning off the WIFI on the Arris worked a charm. No more problems.
Jul 25, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode. DMZ helps wtih double NAT conditions in this case.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
Orbi Wifi would be far superior to anything that ATT has on there modem/ONTs.
mpf541
Jul 25, 2018Apprentice
I have att fiber and orbi. It works great but nyou need to get the right gateway. You do not want to use DMZ with this. What you want is IP passthrough. Set it up with this and the orbi works great.
Make sure yo tell thgem this is what you want. Specify a gateway with IP Passthrough. You can request it and they will ship one.
They do have more bthan one model but this arris i have is the latest. At least when i got it the beginning of them year.
My att gateway is
| Manufacturer | ARRIS |
| Model Number |
BGW210-700
