ATC1125
Jul 25, 2018Follower
Orbi w/ AT&T Fiber
I am looking to switch to AT&T fiber. I currently have xfinity internet for which I use my orbi system. AT&T representative said there would be no benefit to using the orbi with their fiber. Is that c...
- Aug 08, 2020Putting my Orbi in AP (Access Point) mode and turning off the WIFI on the Arris worked a charm. No more problems.
Jul 26, 2018Guru - Experienced User
DMZ can be used if IP Pasthrough is not an option or can't be configured on his ONT.
- mpf541Jul 26, 2018ApprenticeAs someone who uses this service. I had issues with the orbi working properly on DMZ problem solved by just getting the correct gateway to start with. ATT will provide it if youy ask for it. - stevegonSep 14, 2018Tutormpf541 What is the "correct gateway to start with. ATT will provide it if youy ask for it. "I just spent 3 hours on the phone with AT&T and they said I could use a "secondary router"...which I don't want to do. I want a single ethernet WAN cable with an internet address (doesn't have to be static) and no WiFi or router from ATT, period. Nothing, just a single Ethernet port. Any help is much appreciated.- mpf541Sep 14, 2018ApprenticeYou have to use the ATT Router. It is becase they identify the equipment by its serial number. So you can't sppof its mac address. But just put thier equipment in ippassthrough and turn off wifi on its router. The orbi will work fine then.
