ATC1125
Jul 25, 2018Follower
Orbi w/ AT&T Fiber
I am looking to switch to AT&T fiber. I currently have xfinity internet for which I use my orbi system. AT&T representative said there would be no benefit to using the orbi with their fiber. Is that c...
- Aug 08, 2020Putting my Orbi in AP (Access Point) mode and turning off the WIFI on the Arris worked a charm. No more problems.
stevegon
Sep 16, 2018Tutor
I was an early adopter of AT&T Fiber in my neighborhood. I hope that this will provide people with the warning that they need. So you understand, here is what AT&T considers "passthrough" (copied directly from the management UI of my Pace):
Note: On LAN devices which have a Private IP address, once DMZplus mode is selected and you click save, the system will issue a new IP address to the selected computer. The computer must be set to DHCP mode to receive the new IP address from the system, and you must reboot the computer. If you are changing DMZplus mode from one computer to another computer, you must reboot both computers.
See what I underlined: "this computer". In no way shape or form is network passthrough applied from the router to a single IP address...one that cannot be static (due to work requirements). This is not passthrough. My assessment is that this router was designed for a very different purpose, but it was reliable maybe, so ATT kept it and gave it to all their customers. Saves them money...screws over the early adopters who overwhelmingly do not want unconfigurable network equipment.
mpf541
Sep 16, 2018Apprentice
I fail to understand why you keep complaining about the pace modem and you don't just call tech support at ATT and explain the you need a gateway with IP pass through. Your problem would then be solved.
- mpf541Sep 16, 2018ApprenticeThey don't annoy me. I am just giving you a solution that will work. I have done this 2 times with them. Onece when I firts got fiber. It work fine and then the orbi started losing the internet. I blammed ATT and they replacecd the router. I forgot to tell them i needed IP passthrough amd they gave me the pace. All it took was a short call to tell them that the only moden that i can use has to have the IP passthrough. While i admit it is hard to get ATT to understand they also don't want you to go back to comcast. They will swap it. The 2nd time they even sent out a tech to do it.
- ajb313Nov 07, 2018Aspirantmpf541 thank you so much for your insight here. I have an Arris BGW210 AT&T Fiber gateway and I am trying to use my Orbi RBR40 router with 2 RBS40 sats. I am a SUPER novice with anything related to networking, but if I plug the Orbi router directly into Ethernet port 1, what would be my next steps to use the Orbi Router and satellites to establish the mesh network? It sounds like this is your exact setup and you have it working flawlessly. Thanks for any insight you can give this rookie.
- FURRYe38Nov 07, 2018Guru - Experienced UserModem Combo Units:
 Couple of options,
 1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
 2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
 3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
