ATC1125
Jul 25, 2018Follower
Orbi w/ AT&T Fiber
I am looking to switch to AT&T fiber. I currently have xfinity internet for which I use my orbi system. AT&T representative said there would be no benefit to using the orbi with their fiber. Is that c...
- Aug 08, 2020
Putting my Orbi in AP (Access Point) mode and turning off the WIFI on the Arris worked a charm. No more problems.
realisticmccoy
Jul 29, 2020Initiate
My Orbi set up worked fine on Xfinity. Since I've switched to ATT Fiber, a lot of urls ask me to log in.
I can't even see the Netflix.com main page without it prompting me to log in.
The ATT side has an Arris BGW210-700 and I've turned off its wifi and switched it into passthrough mode
with the RBR50's MAC address as the passthrough target.
I'm at a loss for why some urls just have to stop and ask for a router login.
If I switch my phone over to the cell network, it gets into the same urls just fine, but not on the wireless.
The only change was he Xfinity+Netgear cable modem to ATT+Arris switch.
realisticmccoy
Aug 08, 2020Initiate
