MarkZee
May 11, 2018Follower
Orbi Wake On Lan (WOL)
Hi all, I have a Synology NAS and use Wake On Lan to turn it on when needed. I'm considering the Orbi RBK50 and would like to know if this WOL will still work? I'll be using the NAS connected by ethernet to the second unit not the primary one.
Any advice or experience is appreciated.
Thanks,
Mark
Thanks,
Mark
1 Reply
- DarrenMSr. NETGEAR Moderator
Yes it should still work if you have the proper port forwarding set.
DarrenM
