ChuckieCheese
Jan 28, 2017Luminary
Orbi: We really need separate SSID for 2.4 Ghz and 5Ghz or speed is limited to less than 200 Mbps
TLDR: With Orbi, my 5Ghz capable devices are "forced" to connect to 2.4 Ghz most of the time, slowing down speed. Tested against 3 different routers and my 5Ghz capable can connect to 5Ghz network al...
Uplink01
Apr 06, 2017Star
Hi,
As it has been stated a few different times already, once the MacBook connects at 2.4Ghz, unless it drops below -75 dBm, it will NOT reconnect (or even attempt) to reconnect at 5Ghz, or even search for a closer/faster satellite for that matter. This is how macOS is currently designed, you can find the full details at: https://support.apple.com/en-us/HT206207
The bigger question that everyone is trying to help you with, is why is it dropping to 2.4Ghz in the first place. Typically when it is very random like it currently seems to be (after you have reset your Orbi hardware) it could be due to something as silly as a microwave being turned on that is causing the 5Ghz network to not be strong enough for a moment in time and the MacBook is switching to the 2.4ghz band. Then as explained above, the 2.4Ghz network is strong enough that the system will not switch back automaticly becuse it doesn't drop below -75 dBm. So you will have to manaully turn off WiFi, and turn it back on.
I like to use the app, WiFi Explorerm to help me see what is going on within my network. As I do live in a concrete built condo, with lots of neightbors that have lots of different WiFi setups, let alone the wireless devices in my house... :)
ChuckieCheese
Apr 06, 2017Luminary
Uplink01 wrote:Hi,
Yes, I understand. I read every single post and tried disabling the the satellite. Why is it dropping to 2.4 Ghz? From what I've tested so far, from turning off one satellite to keeping the same MacBook in the same place, I have no clue. One thing for sure is that with my old Time Capsule and other routers that support frequency separation, my MacBooks stay connected to 5 Ghz all the time.
With multiple MacBooks and different routers tested (refer to my previous posts) which have dual SSID, so far only Orbi the one that won't hold to 5Ghz. If Orbi have dual SSID, maybe I can test that.
