ChuckieCheese
Jan 28, 2017Luminary
Orbi: We really need separate SSID for 2.4 Ghz and 5Ghz or speed is limited to less than 200 Mbps
TLDR: With Orbi, my 5Ghz capable devices are "forced" to connect to 2.4 Ghz most of the time, slowing down speed. Tested against 3 different routers and my 5Ghz capable can connect to 5Ghz network al...
JMU1998
Apr 13, 2017Luminary
Is it possible to turn off the 2.4GHz on the satellite? The main unit has the option to do so but satellite does not?
ChuckieCheese
Apr 14, 2017Luminary
I do want to keep both 2.4 and 5Ghz because some of my devices only support 2.4 Ghz.
