ChuckieCheese
Jan 28, 2017Luminary
Orbi: We really need separate SSID for 2.4 Ghz and 5Ghz or speed is limited to less than 200 Mbps
TLDR: With Orbi, my 5Ghz capable devices are "forced" to connect to 2.4 Ghz most of the time, slowing down speed. Tested against 3 different routers and my 5Ghz capable can connect to 5Ghz network al...
yashart7
Jun 24, 2017Aspirant
Got mine today and found out the hard way that there is not separate SSIDs for 2.4 and 5ghz. The router provided to me from ATT has this functionality. Not sure why this $350 replacement/upgrade does not. I'm inclined to retutn this. Thanks Netgear
- peteytestingJun 25, 2017Hero
yashart7 wrote:
Got mine today and found out the hard way that there is not separate SSIDs for 2.4 and 5ghz. The router provided to me from ATT has this functionality. Not sure why this $350 replacement/upgrade does not. I'm inclined to return this. Thanks Netgear
its because it designed to automate your wifi environment both in AP steering and band steering , you will find most of the mesh systems work this way as to get the best wifi coverage is to be able to balance those steerings automatically , if you didnt do this the steering would be compromised and make the orbi less effectual
your clients should be smart enough to connect to the 5 gig band if its available and most clients you can force them to connect to one band or another
- st_shawJun 25, 2017Master
yashart7 wrote:Got mine today and found out the hard way that there is not separate SSIDs for 2.4 and 5ghz. The router provided to me from ATT has this functionality. Not sure why this $350 replacement/upgrade does not. I'm inclined to retutn this. Thanks Netgear
A single SSID is required for clients to seamlessly roam between access points. Setup this way, your device will switch from router to satellite, and also from 5 GHz to 2.4 GHz when you get out of range of 5 GHz. This is how most enterprise systems are configured.
What are you doing that requires separate SSIDs?
